VP44 stock replacement or VP44 hotrod?
Discussion in 'VP44 Pump' started by hubert3317, Dec 20, 2011.
  1. hubert3317
    hubert3317 Junior Member
    Dec 20, 2011
    Ram Year:
    2001
    Engine:
    5.9 cummins
    I was wondering if i should put a vp44 hotrod pump or just replace me worn out pump with a stock so pump and replace the injectors with 100 hp injectors?
  2. XtremeDiesel
    XtremeDiesel Preferred Vendor
    111
    Oct 12, 2011
    Wall Township, NJ
    Ram Year:
    2008
    Engine:
    6.7L
    It all depends on what you want to do with the truck. There is guys that make power with standard output VP44's. However, if yours is out now it might be a good time to upgrade. Whatever you do make sure you have an adequate lift pump to supply pressure to your new VP44.
  3. ramhunter9
    ramhunter9 Supporting Member
    24,508
    886
    Jun 25, 2010
    Ram Year:
    Engine:
    P-Star Jeep Wrangler
    Make every repair a upgrade
  4. XtremeDiesel
    111
    Oct 12, 2011
    Wall Township, NJ
    Ram Year:
    2008
    Engine:
    6.7L
    Good way to look at it.
  5. WhiteExpress
    WhiteExpress Senior Member
    17,826
    3,102
    Sep 8, 2011
    Carlsbad, NM
    Ram Year:
    Engine:
    3.5 EcoBoost
    That has always been my opinion as well.
  6. Mopar1973Man
    Mopar1973Man Senior Member
    47
    825
    Aug 22, 2011
    New Meadows, Idaho
    Ram Year:
    1996, 2002
    Engine:
    1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
    I would suggest the SO pump (stock), then add a Edge Juice/Quadzilla Adrenaline, and then some 50 HP injectors and you'll see a good amount of power. Very controllable and actually really good for MPG's.
  7. XtremeDiesel
    111
    Oct 12, 2011
    Wall Township, NJ
    Ram Year:
    2008
    Engine:
    6.7L
    This is also a good plan. Don't forget about a lift pump upgrade!
  8. ramhunter9
    24,508
    886
    Jun 25, 2010
    Ram Year:
    Engine:
    That's what I have above. Works great
  9. Mopar1973Man
    47
    825
    Aug 22, 2011
    New Meadows, Idaho
    Ram Year:
    1996, 2002
    Engine:
    :naughty: Great minds think alike...
    Yeah you right...
  10. hubert3317
    Dec 20, 2011
    Ram Year:
    2001
    Engine:
    5.9 cummins
    Thank-you so much. I think i will go with the injectors and new pump/edge. It sounds like a really great combo. I put a fass dbrp 02 on it will that be enough pump?
Share This Page
