Want to ad a bigger overhead console
Fourbynut
Lancaster,PA
I have a standard overhead console in my 2008 Ram Quad cab, would like to add the one that has a sunglass holder. The mount for the original one is smaller. I know the headliner must be cut out for the extra pocket of the glasses holder. Has anyone done this without getting a new mount just using whats there?
MK82
Houston, Texas
5.9 HO Cummins
I would imagine, as long as all the wiring is the same, shouldn't be adding any electrical components, if you could find one in a salvage yard you could take the bracket and the console and it wouldn't be too bad of a swap. Granted if there are any issues with the line up of the original bracket to the larger bracket that might be a problem. But then again I doubt they would have changed that much a out the mounting locations since I would think the large majority of the trucks came with some sort of overhead console, it was just a matter of what bracket to attach per the build sheet.
Good luck boss. This sounds like something i might consider a bit later for my 07 too.
Matt
F
Fourbynut
Lancaster,PA
I looked at it closer and the front where it snaps in is different from the original one. Maybe like you said if I can get the proper bracket for it to fit. The console I bought was from a 2005, apparently they did change the mounts on the 6-8 years.
MK82
Houston, Texas
5.9 HO Cummins
Fair enough, it's kinda weird, 06 to 08 (as far as I know) was just a face-lift it's crazy they made such small changes to interior pieces... well let me know what else you find out, I'm going to look into it some more as well.
HemiLonestar
MD
A picture of yours would help tremendously; wondering if you have a sunroof. I did this swap in a 2003 about 12 yrs ago, while I did have to cut the headliner I was able to use the factory mount that is glued to the roof.
F
Fourbynut
Lancaster,PA
I have to post a picture. I do not have a sunroof. I may just be able to modify the front mount tabs and cut out for the longer housing at the sunglass holder. I will post pictures then showing the difference between the two of them.
F
Fourbynut
Lancaster,PA
Here is what I’m working with. The original smaller overhead console and the larger one I want to add. The front mount pins are recessed further than the original. I think I’m going to trim the front case of the larger one so the pins are out like the original one. I’ll let you know how I make out.
F
Fourbynut
Lancaster,PA
Ok so I trimmed the front plastic down so the tabs are about the same height as the original smaller console and it fit. I then notched the headliner so the sunglass cavity would fit in it. I also had to drill two holes in the console to match the original so I could put screws in to hold the rear of it up to the ceiling,the holes were drilled under the plastic light area, I also put the original display in the console as the one in the 05 would not work properly.
