- Jan 17, 2016
- 14,066
- 24,386
- 14 Sport
- 5.7
I appreciate everyone help in here! I think I'm gonna go with the Belltech 2/4 with a Hellwig rear sway bar and the Ford F-150 Front sway bar links. Are there any modifications on those sway bar links to make them work or do they fit perfect? Now my last question is about the illicit brackets to center the rear axle. Are those actually needed with the hellwig rear sway?
The Ford front endlinks are a direct bolt-on.
I'm running the Illicit "Cut " brackets,and they're one of the best things I've done to the truck. I had issues with wheelhop on my lowered RCSB 4X4 and a bit of a high speed wobble above 125,. With Illicits brackets I no longer have either issue,the truck launches hard with no wheelhop,and above 125 you can literally drive it with one hand. I had both issues before hand even with Hellwigs swaybar set on the tightest setting along with their shorter adjustable endlinks,adjusted so the bar is parallel with the ground and an adjustable track bar.
The brackets are a bit of a pain to install,but well worth it in my opinion.
