Warlock Grill
ThePunisher
Harrowsmith
Hello!
I just purchased a 2022 1500 Warlock and have already managed to put a large stone through the grill. I avoided any serious damage, but the honeycomb portion is damaged. Are there any after market grills for the Warlock? I'm not a fan of the Warlock grill and would be fine with just a mesh grill... but I cant locate any grills that fit a Warlock, and Mopar wants about $700 for a replacement grill. Any thoughts?
Administrator
The Warlock grill should be the same a the Gen4 Rebel grill.
If your thinking of upgrading the bumper, any +13 MY Gen4 grill and bumper combo should work provided they accommodate the front parking sensors if equipped
T
ThePunisher
Harrowsmith
I was hoping to just change the grill, not the bumper as well. I wondered if anyone made an aftermarket warlock grill that allowed you to keep everything else.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
With the Warlock sharing the same grille/bumper as the Rebel, as @crash68 mentioned, and since the trend on 4th gens was to upgrade one's Big Horn, Laramie, Tradesman to the Rebel front end and not the other way around, I doubt you'll find any aftermarket grilles to convert your Warlock to the crosshair grille that works with the Warlock/Rebel bumper.
GRKN
09-12 1500 grilles should fit your truck just fine. It’s the 13+ grilles that have notched lower corners and don’t line up with the rebel front end.
GRKN
Ok, after looking up the pics, there is a bit of a hump in the middle of the warlock bumper I hadn’t noticed. Not sure how well it would fit around that. Pretty positive it would line up and bolt up besides that though. I’d try to find a 09-12 grill on fb marketplace for cheap and/or the seller is willing to let you test fit quick before purchase. Takes like 3 minutes to pull the grill if you know what your doing.
Another cheaper option would be to order some generic mesh, pull all the old honeycomb out and replace it. Since it’s all done from the backside there’s plenty of margin for error.
RedRAM21
SoCal
5.7L HEMI
Here is a replacement grille...
RedRock Rebel Style Upper Replacement Grille with LED DRL; Matte Black(19-23 RAM 1500 Big Horn, Laramie, Lone Star, Tradesman), Item R123625"
Link: https://www.americantrucks.com/redrock-4x4-ram1500-rebel-style-upper-replacement-grille-with-led-drl-matte-black-r123625.html?utm_content=AT Exterior - Grille|RedRock&T5_Var4=R123625&utm_campaign=ATR+Ram+Vehicle+Medium+LTVMiddle&dialogtech=ppc&utm_source=google-pla&utm_medium=shopping&T5_Var2=shopping&T5_Var3=red&gclid=EAIaIQobChMIrKbi5o2XgAMVbRatBh2kng_FEAQYASABEgKsvvD_BwE&gclsrc=aw.ds
Similar to the Rebel but with three lights in the grille; $300.00.
There are others out the too.
GRKN
That’s for a completely different truck. OP has a 4th gen, that grill is for a 5th gen
T
ThePunisher
Harrowsmith
Same problem - wont fit my Warlock - these grills are meant to go on regular Rams to make them look like a Warlock without needing to change bumper etc...
