Water for now?!?!?
Toeknee
Just replaced my thermostat, spilled some coolant. Can I replace it with water for now till I buy some coolant from the dealership??????? Thanx
Administrator
Use distilled water, depending on how much you lost, the freeze point will raise. If your not expecting below freezing temps you'll be fine.
ExpressRules
Southern New Jersey
2014 Express Crew Cab & 2019 Big Horn Crew Cab
How much coolant did you lose?? Unless it was a large amount and you are afraid of over heating just pick up the proper coolant when you can and add it to the recovery tank. Adding water will not cause any issues, but as was already said distilled is recommended.
T
Toeknee
Awesome, thank u gentlemen. Another question if I removed the clutchfan, should I reattach that fan shroud thing or just leave it off????
sbarron
Wasilla, Alaska
Always, always put shrouds back in place. They are there for a reason.
T
Toeknee
Awesome thank u sir, just purchased the coolant. Do I flush everything out and replace or just top it off with coolant???????
ExpressRules
Southern New Jersey
If you are sure it is the correct coolant you don't have to flush anything, just add to the overflow tank.
T
Toeknee
Awesome, I hope so I bought it at the stealership...
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
Looks like you got it all worked out.
Something that a lot of people don't seem to realize is that antifreeze doesn't just keep the coolant from freezing. It has lubricants in it for the bearings of the water pump & keeps the block, seals, & gaskets from corroding.
Buddy of mine at work took out his water pump from running nothing but water in it for too long. My brother did the opposite, thought more is better, & ran nothing but pure antifreeze & it ate up his head gasket. Most of the time there is a good reason to do what the manual says. :naughty:
T
Toeknee
doesn't say anything about OAT on the gallon, but went to dealership and gave them year of my truck and they sold me some coolant.
Broyd
Rossland BC Canada
The MOPAR part number on the jug from Amazon is OAT in the link you posted.
That part number is 68163849AB. You should be OK. 50/50 is what you normally use unless you have extremely cold weather.
Did the dealer sell you a jug? If so that part number should be in the bottom left of the label on the jug ( as it is in the link you posted ) . Having the part number is the only way to confirm the right stuff.
T
Toeknee
My last numbers are 48
Broyd
Rossland BC Canada
I found this doing a google search.
Mopar 10yr Coolant for
For: 2013-2017 Chrysler, Fiat, Dodge, Ram, Jeep Vehicles
68163848AB- Concentrate
68163849AB- Premixed
You are good to go :)
T
Toeknee
Awesome thank u kind sir....
