Weighed the truck today
myoung84
Tulsa, OK
2012 Power Wagon
I picked up the boat today and decided to swing into the CAT scales real quick and see what everything weighed. First, I weighed the truck and boat together and then the truck by itself.
Truck: 7300 lbs (~7100 lbs without me)
Boat: 3460 lbs
Total: 10,760 lbs
When I did the total weight they showed my steer axle as 7600 lbs and my trailer axle as 3160 lbs, so my boat has about 300 lbs of tongue weight. Once I toss in my ATV and other crap in the bed I've got about 1200 lbs in the bed and on the hitch, which drops me about 2".
If you take away my bed cover, recovery gear, and other miscellaneous crap in the truck, it probably comes in around 6900 lbs stock with a full tank of gas. I had about a 3/4 tank when I weighed in.
And here's a couple of pics with everything loaded down for the weekend. The weights above don't include my ATV, which is another 800 lbs. Fully loaded down for the weekend, I'm probably around 12k lbs.
Sagebrush2500
2013 2500 Big Horn
And with the Hemi pulling and the 2500 suspension, you probably feel empty!
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
spiffy!!
Txhillbilly
2012 Dodge PowerWagon
Good looking truck and toy's.
I was thinking about powdercoating my bumpers,and after seeing yours,I have to do it now.The bumpers look very good.
What size Arctic Cat is that? I have a 550,the same color.
Stangshcky12
Oshkosh, WI
5.9 Cummins
Your total weight is less then the trailer I pull lol
That sure does look like a good weekend!
I bet the 4:56 gears really help out
I'm always curious about actual weights, I like to stay within weight ratings
I have a guess of what the 05 weighs but would like to know for sure
My f350 dump truck was 9400 empty and the skid steer I pull weighs 9,500 and the trailer is somewhere around 3,500 pounds
quietpeen
2021 TRX
Hellcat
is that the stock suspension in the rear or do you have air bags? Asking due to the very little squat you have with a quad and the boat trailer hooked up.
Lol...a feather falls in a the back of a 1500 and it squats.
jlb
MT
CTD
Comically enough, your whole setup was what I once pulled with my 85 Chevy... Even got to take the whole rig 4 wheeling when some ******* in a Dodge cut off the semi in front of me and he smoked his brakes trying to stop lol. I would have only hit him at about 5 mph, but I figured that weighing that much it still would have put his bumper into my cab. I rolled across the scales at 26,660 lbs... I may or may not have been slightly overloaded...
Stangshcky12
Oshkosh, WI
5.9 Cummins
Lol Im not a fan of pulling it with a 6.0 diesel, couldn't imagine it in an old Chevy lol
I bet the drum brakes really helped you out then! haha
jlb
MT
CTD
Well, the trailer brakes did most of the work, tandem axle dually trailer and I locked up all 12 tires (briefly in the truck lol) until my rear end started getting too squirrely(?)
I will say I prefer discs (of course), but those old trucks had such huge drums, and wide that when well maintained they worked pretty well as long as they weren't getting super hot like when you come down a pass or something.
The motor in the truck was pretty heavily modified, it put down just over 400rwhp, and pulled the trailer as well as my dad's 05 CTD (mostly stock just a tuner). The Chev was originally a gift to me cuz he liked his newer trucks better, then he ended up jealous of everything except my gas mileage.
This new ram in my sig is the replacement, and I miss the power I had in the Chev lol, but most of the rest is a lot nicer...
suzukiquadrider
cummins 5.9, 6.6 duramax
looks like a great weekend was had!
myoung84
myoung84
Tulsa, OK
2012 Power Wagon
It was definitley a good weekend. I've pulled this same load with my 2010 1500 and the 2500 with the new 6 speed and 4.56 gears does a ton better. And I get about the same MPG as the old truck, which is about 10 mpg...
The bumpers were on the first to do mod list before I even picked the truck up. I didn't want chrome at all. Best $200 I've spent in a long time.
My Cat is also a 550, and looks identical to yours, when it's clean... It's been a great ATV, I am currently at 31 hours and about 290 miles so far...
CumminsCrazed
North Central Iowa
5.9 Cummins 24v
yes...our trucks are def heavy....heres mine with the load pictured below and scaled with a half tank of fuel
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
Goodness, that thing is heavy !!!
MY 97 3500 dually 4x4 12v only weighed 7200 lbs........until I put the spare fuel tank in it...LOL.
