Bullitt5339
It has a small hole but the flange is just round and the drive shaft bolts to it, not like the old yokes with the ears, I put two bolts in and tightened them to my pry bar and pinned it against the gas tank, torqued to 210 and it still seemed like too much play/loose, so I hit it about another quarter turn with the impact, just took it for a spin and has a good vibration, and letting off a little whine/groan, so is it still too loose? Will that also cause the vibration?
Sent from my SCH-I545PP using Tapatalk
Did you put a new crush sleeve in it?
If the answer is no, did you measure the torque before you pulled the nut off?
Have you measured the preload? How tight it feels means nothing, it's all about the preload on the bearings.
If the answer is yes, are you sure that you've actually crushed the crush sleeve? You can hit the torque value and preload value prematurely before the crush sleeve gives way which completely jacks things up and it'll fail quickly, such as the symptoms you have.
The preload is the key, without it being correct, nothing else you do will matter.
