What do you tow with you 6.4
22hemi13
Tucson AZ
2014 2500 4x4
Yeah. That’s a beastly trailer lol. Very nice. Just out of comfortable capacity of a gasser. No knock to the 6.4 at all. You just outgrew your truck. It happens
SETEX 6.4
Port Neches, TX
I get it man. That's a whole lot of trailer. Definitely diesel worthy.
2014 Ram 2500 Mega Cab 6.4 Hemi 4:10 Gears Ram Boxes 35x12.50R18 on Factory Wheels
Sent from my SAMSUNG-SM-G891A using Tapatalk
bluefishgary
Middle River,MD
Hi Beautfull trailer. Now i have 2015 DRW c/c long bed 6.4 that came with 3.73 rears. My trailer is a Millennium 44 ft
G/N weight is about 9,000 lbs empty loaded 14,000. Its a 3 axle .Mine was the same as yours a little slugish so I changed both
gear sets to 4.88. Pulls GREAT now!! Can stay in 5 gear most of the time. Fuel milage is at best 9.5.mpg
I also add a fuel tank /tool box combo in bed (60 gal) I go about 700 or 800 miles then get fuel.
22hemi13
Tucson AZ
2014 2500 4x4
Such a shame they can’t put better gears in these truck. High gears work on flat land. But any terrain change and they suck. My 5.7 is fine in my 2500 if it’s FLAT. I don’t live in flat land haha
CincyCuda68
Ohio
33’ travel trailer
28’ travel trailer
21’ boat
68 Barracuda
Various bobcats
6797A9F4-F82B-47CC-B467-1FBAD2F4DA7C.jpeg 5D0B488E-E7D3-4E8A-9E20-595DFADECD27.jpeg
tjfdesmo
AZ
Thanks. Sounds like a great setup you've made! So do you have the factory 52 and 22, and 60 gallon aux tank? I assume the C&C came with the Aisin?
On Edit: I assumed you meant cab & chassis, but could have meant crewcab.
Megazor
Well, I am back from Oklahoma with my Sundowner. The good news is the chassis with 30 psi in the Airlift bags handled the weight with absolutely no problem. No bucking, no chucking, no hobbie-horseing whatsoever. Absolutely calm going down the road. Did over 900 miles Thursday.
The less than good news is, as I feared, the 6.4/66RFE will do it under protest, but are not up to this task. This trailer is just under 12K absolutely empty. On flat ground and lower elevation, cruise set at 65, it would pull 5th gear , around 22-2300 rpm,reasonably well, sometimes 4th at around 27-2800. Add some elevation, and/or a little more roll to the hills, and 3rd at close to 4000 rpm. More elevation and steeper pulls by Albuquerque and south of Flagstaff and just too much time in 2nd gear spinning 5000 rpm for miles. To its credit, speed would drop off to 60, and she would hold it. Engine braking on steep downgrades was not very effective with this much weight. None of these were "legendary" grades, either.
MPG was mostly in the 7.5-7.9 range, which is pretty much what I expected. Couple that with the too small tank, with no aftermarket solution, and the range simply sucks. Hard to milk 200 miles out of it. Spent way too much time searching RV accessible fuel stops while driving. The chassis-cab with 74 gallons on board would be much, much better.
My Winter use will be mostly dune and desert destinations, so she'll get the job done, but I will have to go back to a Cummins for the locomotive torque, and the peace of mind of the exhaust brake.
Before anybody gets their panties in a bunch, I am not bashing the 6.4. These are my findings as someone who has towed a fair amount. Also, this trailer was not in the cards when I bought this truck. Life happens.
View attachment 144716 View attachment 144715 View attachment 144716 View attachment 144717
Hats off to you, I would have never even considered pulling that with my 6.4. That is a big beautiful beast.
tjfdesmo
AZ
Well, I grew up in the lumber business driving grossly overloaded trucks, including medium duties at gross weights that would be CDL territory today, and those trucks all had gas motors with less than half the horsepower the 6.4 has. As much as I think the drivetrain is overmatched in my case, I am also grateful to not be grinding up the hills at a snail's pace with the four-ways flashing, and my arm out the window waving angry drivers around me like "the good old days":D:D:D
Alexpaul09
Indiana
I have a 2014 2500 with the 6.4 and 3:73 gears. I tow 7,000 cargo trailer loaded with construction equipment and it works great! A buddy of mine has a f550 service truck with a crane and loaded with well parts and fittings, weighs 22,000lbs rolling, it broke down and I had to tow him 6 miles up a few good hills and got up to 50mph on the high way. Taking off it was grunting but did a lot better than I thought! These 6.4's are tough gassers
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Dang! That's great to hear man! I can understand what your saying though. First gear could be steeper in our 6 speed or just a lower standard rear gear for an HD truck like 4.30s or something like that
WAKEMASTER
WISCONSIN
20180513_131710.jpg 20181014_102900.jpg I have been very pleased with the performance and the stability of the 2500 6.4. I have also been somewhat pleased with the MPG out of a 2500 gas motor. I put the cruise on at 65 MPH and get around 6 MPG towing this load.
People think that if they feel the load behind their truck their engine is to small. I have towing bigger boats than this with my stock 2000 cummins and never thought I needed a larger motor. Now the new diesels have over double the Torque that that truck had.
theviking
That's impressive! What does that behemoth weigh?
WAKEMASTER
WISCONSIN
I have have never put the boat on a scale. If I had to guess it would be around 15K. Could be a little more :)
The only complaint I have towing is the transmission ratios in 2nd gear, getting going on a steep hill is a challenge.
sandawilliams
Pueblo West, Co.
6.4 hemi
Even the big boys (semis) wont stop on a steep uphill grade with a heavy load if at all possible.
theviking
Another issue I've seen on steep hills is wheel spin. Watched a dually Powerstroke pulling a heavy horse trailer try to get started and just spin repeatedly. Finally had to back down the hill after clearing all traffic.
22hemi13
Tucson AZ
2014 2500 4x4
4x4 ;)
NewBlackDak
Hemi 6.4L
View attachment 148837 View attachment 148838
Tons of trucks towing with straight/slant 6s and 3-speeds would agree with you.
Mountaineer83
Charleston, WV
42' and 13k empty, probably 14k loaded. I do have the 4.10 rear, but hope to go 4.88s eventually. No Cummins, but she gets the job done just the same!
I had my hitch too far back in this pic, so it squatted a little more than it does now. Drops about 2" before I air up the Firestone bags.
