What is required in order to switch my computer from NGC to jtec
Nunie94
New Orleans
So I put a 03 4.7 in my 05 truck and it’s not starting. I’m thinking this 03 engine is jtec I have to verify still but if it is what would it take to swap the computer systems. From my research I know I need the pcm and tcm and the harness from the engine and transmission. is there any more I would have to change cause I really don’t want to tear the engine down
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
It might be 04 is a MAP instead of throttle position for AF
I’m not positive but other Chrysler models changed between those years
Mister Luck
WEST COAST
5.7 V8
Depending on where you live in your state to register your truck…
if they have mandatory vehicle testing you may need to use the same year or newer emissions devices including PCM’s
