What is this for?
JPT
NY
2015 Big Horn
Hello everyone, I am a new ram owner. Loving it so far. I picked up a good runner with 82k miles that just needs a little TLC.
Anyone know what this part is for? I just got this truck, and found it hanging loose between the bumper and the inner fender. Thanks.
Specs:
2003 5spd 4.7L 4x4 regular cab extended bed. Baseline, no power anything.
Pictures:
moparman
Woonsocket, RI
2016 Ram 2500
ambient temp sensor. normally is attached where the headlight is bolted to the fender on the front
JPT
JPT
NY
2015 Big Horn
I don't have an ambient temp gauge. Would this be installed even without it?
MegaMouseGW
South Louisianna
SRT 10 Viper Motor and Tranny
Yes I also have that and I believe it is used for the temp gauge in the cluster when you swap your trip meter.
JPT
JPT
NY
2015 Big Horn
Never realized there was a temp gauge there. Will have to play.
Thanks all!
MegaMouseGW
South Louisianna
Thanks all!
Yeah at least mine has it. When you hit the trip button to co to the trip mileage hit it one more time. Should bring up a temp gauge. Most people do not even realize it is there because they reset the trip meter and let it go back to the regular mileage by itself.
HemiLonestar
MD
There should be a flat spot on that bottom bolt on the driver's headlight. If you have aftermarket (non-oem) headlights, you may not have that flat spot. A dremel will quickly fix this.
JPT
JPT
NY
2015 Big Horn
I just checked. I do not have a temp gauge when I cycle through the odometer and tripmeter.
cfodor
Banned
it is a temp sensor for sure just because it is not on cluster it does not mean the truck does not use it
JPT
JPT
NY
2015 Big Horn
I know some manufacturers put sensors on that aren't used just because it is cheaper on the assembly line. Not saying that is the case here. But why else would a vehicle have an ambient air sensor, without the gauge?
My Audi has tons of them for climate controls, uses a temp difference from outside to inside to determine levels. But this is no Audi...
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
Its for the overhead console not the cluster but regardless, it is the ambient temp sensor. Could just be prewired for those who want to install a overhead console from SLT+ models. Same with models also having prewired wiring harness for fogs (lower drivers side) but no switch or fogs.
See circle area of where it should bolt up to per HemiLonstar
JPT
JPT
NY
2015 Big Horn
Yup. That's what I figured. Cheap sensor vs. expensive assembly differences.
mrfyram1500
2024 1500 Laramie
Ohio
I installed a power driver seat when I had my '08 SLT. It was built with a manual seat but the harness was wired for a power seat. Even had the fuse installed in the box.
JPT
JPT
NY
2015 Big Horn
Nice. Maybe someday, I'll look into adding features.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
On the 02-05s (for sure) the air temp readout will be in the little trip computer integrated with the map lights on the SLT and higher trucks.
