What size door speakers?
Jerry1984
Meridian, Idaho
2014 express with uconnect 5.0 and basic radio. What speakers fit in the front and rear doors? I'm reading 6x9 front and 5.25 rear, but then crutch field also says 6x9 will fit the rear? I would like to go 6x9 all around and understand depth can be an issue. Read 2.75 inches is the max. So my question is will 6x9s fit all door speakers? Thanks. Will just be running off the stock head unit for now and won't be a huge system. Just want to get rid of blown rear speakers and a little better sound.
jknappen
Kentucky
6x9 front and rear 3.5 in the dash
jknappen
Kentucky
Alpine spr-69 fits perfect screw holes line up exact
Jerry1984
Jerry1984
Meridian, Idaho
Upon a little more research, I found the rockfords have a 2.85 inch mounting depth. Ordered them from Amazon so hopefully they work. Right at $100 with wiring adapters for all 4. Cheap, but can't lose for that price.
popcenator
Omaha, NE
They're not bad, just a little inconvenient to get to the bolts due to how close they are to the windshield.
jknappen
Kentucky
Did mine with a 1/4 inch ratchet..... Piece of cake brother takes less time and effort than the doors. Just order the adaptor harnesses from crutchfield and its gravy.
Jerry1984
Jerry1984
Meridian, Idaho
Thanks guys. I'll see how it sounds with the new 6x9s and think about the dash speakers if necessary later!
Solej
I replaced all my stock speakers and I am running the stock nav radio. Check out my post, I listed the speakers I used.
JBK327
Oklahoma
I just installed a jvc head unit, zapco amp, and a sundown audio 8 inch subwoofer. If you have premium factory system the 6x9's in the front doors are woofers only. New 6x9's will not provide any highs.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Jerry1984
Jerry1984
Meridian, Idaho
I do have to pull the door panels for the install correct? The speaker cover area doesn't pop off? Thanks.
Solej
New dash speakers are one of the most important swap, you will notice a huge difference with those alone
DTX214
Installed 4 6x9 Kicker speakers on the doors on my 14 Express, skipped on the dash speakers but if you get a chance if definitely get em while your at it.
Jerry1984
Jerry1984
Meridian, Idaho
Thanks guys. May order the kicker 3.5s for $30 if I don't like the sound improvements.
Jerry1984
Jerry1984
Meridian, Idaho
Well that doesn't happen often where a project goes quicker/easier than expected. Had everything done in an hour and a half. Well worth the hundred bucks. The door is held on by poppers, there was a how to online where the guy actually screwed them out. If you just pop the screw part out and then the base it's much quicker and easier. There is quite a bit more bass than the stock speakers and I was able to reuse stock mounting holes and screws.
JustinRam1500
