what would you do first?
Oefootball_70
OLATHE
I say wait until you have money to do lift wheels and tires and exhaust all at once.
4X HEMI
Lancaster County, PA
Just depends how big the pocket book is, sometimes you just have to do a little bit at a time.
bigtigga84
bigtigga84
dela....where?
^^ not a pocket book......... more like a change purse at this point lol
reefguy89
laurel de
i say lift the exhaust aint that much u can get it done at luckys in delmar for 300. u gonna go body lift? if so let me know i would be willing to help as i want to add a body lift eventually.
OklaHemi
new age hemi
at least he didnt say fanny pack
bigtigga84
bigtigga84
dela....where?
lmao, i see enough of that in the summer with the tourons...... big negative ghost rider. but hey, if hulk hogan can rock one......NA!
bigtigga84
bigtigga84
dela....where?
so i went and talked to the shop about my exhaust. gonna be about 125 to have it dumped before the fender. was just going to do that until i decided on how i was going to lift a little more. while i was there, the guy at first wanted to argue with me about how many cats i had. he swore up and down i only had one(had worked on earlier models). after that got straightened out, we started talking back pressure and torque. he suggested that i run a dual set up with two mufflers. i already have a magnaflow y and cherry bomb extreme. want the magnaflow y put in (had to persuade him there was room to fit the y). so new y to cherry bomb single in dual out. duals 45'd out the back. which set up do you guys think would be best?
ramhunter9
P-Star Jeep Wrangler
CB is loud ... I had one to loud for me
RubberFrog
You're better off with a si/do then dual mufflers. And don't listen to the exhaust shop guys. They always act like they're an expert on every vehicle out there. They know as much as the stealership guys do.
matt99
Shreveport, LA
Ive got a maggy SI/DO dumped right before the axle and I like it. It sounds good from the outside and virtually no drone. Compared to the straits from before its silent
bigtigga84
bigtigga84
dela....where?
I like it loud though that's why I got the extreme =0). I figured the true duals would be less back pressure and less torque. I got him a couple times walkin in there known what I was talkin about. I was amused by it
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
You could run a mag y then a cut out with a single in dual out mild muffer so you will have the best of both worlds and change it when you want.
matt99
Shreveport, LA
False. It will give less backpressure but no real change in torque. Better mpg though!
I had straits and got better MPGs than with this Magnaflow but not anything worth ranting about. The torque "feeling" is the engine recouping the pressure with gas. I dont remember the specifics though.
ramhunter9
Better in than out ..... shreck
bigtigga84
bigtigga84
dela....where?
Was yours straigh(h style)? Way the guy was talkin about running it was following how the factory exhaust runs.
matt99
Shreveport, LA
Yea mine ran the same way as the stock exhaust with an X pipe. An "H" pipe isnt quite as efficient as the "X" higher in the RPM range and the "X" isnt as efficient in the low end. The "H" is a little louder too.
It also depends on the muffler you use (if you use one). For a less baffled muffler use an X, or for something like a flowmaster a H.
Obviously the X is going to allow the exhaust gasses to equalize a little more thus decreasing backpressure. Probably better MPGs. So it depends on what u want
