What's the smallest tire for 17x9 wheels
CoreyLRam96
Can anyone tell me the smallest tire size I can go for 17x9 wheels?
CoreyLRam96
CoreyLRam96
Bump
BBartow
New Port Richey, Florida
5.9L Magnum
I'm confused are you asking for smallest or biggest because in your other thread you wanted to know the biggest tire you could fit
CoreyLRam96
CoreyLRam96
Tell me the biggest tire I can run, and the biggest wheel I can run on said tire. And biggest tire with smallest wheel as well. Sorry for not being clear
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
you could run 37s or even 31s, or 18s if you want to depends on a few variables, lift, gear ratio, etc.
dapepper9
Iowa/Nebraska Border
5.9L V8
I think we're all still confused as to what exactly you're asking
CoreyLRam96
CoreyLRam96
Can I fit 17x10,17x12,etc. on a 265/75r16 and can I fit a 275/55/20 tire ?
DodgeTx
SEGUIN
you cant fit a 16 inch tire on a 17 inch rim no matter how hard you try. Nor can you mount a 20 inch tire on a 17 inch rim. You are a funny troll.
dapepper9
5.9L V8
Here's how you break down tire size:
Take 285/75/16 for example.
285- width of the contact patch in millimeters, so this tire is 285 millimeters wide.
75- height ratio, the measurement from the contact patch to wheel mounting surface is 75% of the wheel width measurement. So, the sidewall is 0.75x285=213.75 millimeters. So tire height is 213.75 + 213.75 +wheel diameter
16- this is your wheel diameter, whatever your 3rd number is that's the only size wheel this tire will fit on. NO exceptions
Final tire sizing-
285 millimeters wide (roughly 10.5" wide)
213.75 + 213.75 +16 (roughly 33" tall)
16 inch wheel
JustinRam1500
