Wheel hop 2500
Discussion in 'Heavy Duty' started by Dmopar74, Jan 9, 2017.
  1. Dmopar74
    Dmopar74 Senior Member
    37
    367
    96
    Jan 10, 2016
    Ram Year:
    Engine:
    Anybody else have wheel hop problems in the soft stuff, deep sand and snow gets the reared bucking very bad. My truck does have the 5th shock on the pumpkin.
  2. Broke pilot
    Broke pilot Senior Member
    313
    91
    Mar 1, 2015
    Conroe, TX
    Ram Year:
    Engine:
    6.4L
    With a 5 link rear you shouldn't be having any wheel hop issues in soft stuff. Maybe a bit if you were trying to burn the rear tires off on pavement. Aside from any deflection in the crappy rubber bushings Chrysler uses, there should not be any axle wrap.
  3. bcbouy
    bcbouy Senior Member
    1,084
    398
    Nov 12, 2014
    pitt meadows
    Ram Year:
    2012 ram 2500
    Engine:
    hemi
    my front hopped around pretty good when i had the 33 nitto's on and i got my foot into it.it just made 4 wheeling more fun though.haven't been out wheeling with the 35's yet,too much snow.
  4. 1500ram12
    1500ram12 Senior Member
    2,482
    325
    Jan 23, 2012
    Ram Year:
    Engine:
    6.4L Hemi
    I get it to with the 5th shock, it's just the design of the 4 link. It's designed for road manners not off road. If the used a triangulated 4 link in the rear you wouldn't have the bouncing of the rear axle in soft material. The front will shake and bounce no matter what the design
    Sent from my SM-N920V using Tapatalk
  5. Gear Jammer
    Gear Jammer Member
    71
    21
    Sep 25, 2016
    Yacolt WA
    Ram Year:
    Engine:
    My truck does it. Usually on pavement in two wheel drive I don't have any wheel hop, I don't have the fifth shock. Where it's been bad for me is in 4wd in the snow, spinning all 4 tires from a stop. I haven't had my truck in sand yet, but I'm guessing it will behave pretty much the same as it did in the snow.
  6. sbarron
    sbarron Senior Member
    2,727
    1,538
    Feb 28, 2015
    Wasilla, Alaska
    Ram Year:
    Engine:
    The cure for wheel hop is simply to let up a touch on the right pedal. ;)
  7. bcbouy
    1,084
    398
    Nov 12, 2014
    pitt meadows
    Ram Year:
    2012 ram 2500
    Engine:
    hemi
    huh?
  8. Ghetto Fab.
    Ghetto Fab. Junior Member
    20
    Jan 16, 2017
    Ram Year:
    Engine:
    6.7 CUMMINS!
    You guys getting wheel hop while the bed is empty? Its probably mostly due to the crappy rubber bushings in the rear control arms. I noticed the other day driving the work truck that when coming to a complete stop the truck bounces back and forth. Kinda like the axles have stopped moving, but the truck is bouncing back and forth in the rubber bushings. Our jeeps do it too. Its just an odd feeling.
    Suspension geometry might also contribute a bit, but I doubt it. I need to measure the work truck to see how much anti-squat is in the stock suspension.
    Kevin
  9. Gear Jammer
    Gear Jammer Member
    71
    21
    Sep 25, 2016
    Yacolt WA
    Ram Year:
    Engine:
    Where's the fun in that? :roflsquared:
  10. loveracing1988
    loveracing1988 Senior Member
    3,389
    843
    Jul 4, 2013
    Clarkston, MI
    Ram Year:
    Engine:
    The bushings don't help but it is the design of the suspension that causes this. People on the power wagon forum have been complaining about it ever since they switched from leaf springs. I don't have many issues in 2wd but in 4wd if you are in any kind of deep snow the whole truck tries to shake itself apart.
    Sent from my Nexus 6 using Tapatalk
Share This Page
