xb1230
Hobby Mechanic
- Aug 22, 2014
- 960
- 226
- Location
- South Shore of Montreal, QC, Canada
- 2020
- 5.7 HEMI
2002 RAM 1500 QC Long Bed 4x4 175k Miles (no lift or lowering kit).
I'll make this as short as possible while providing the most information for you folks to help me out on this one.
Last week I put my Winter tires on and started noticing a grind in the front. Was not sure if it was there or not before I swapped my Winter tires on so just let it be a little while. Today as I changed my oil, I took the opportunity to swap the front wheels to see if the noise would follow the tire and eliminate a potential bigger issue.
Sure enough the tires are not the cause, so now I need some help in understanding how to diagnose whether the noise is coming from a wheel bearing or something further up in the drive train.
Noise is like a grinding noise or hum with a small oscillation that increases with speed, so it is definitely between the wheel and the Axle.
I have tried giving sharp turns to the front to see if I could hear a change in the sound as in the past I was thought to assess a wheel bearing issue like this, but there is no change in the noise, does not increase or decrease no matter how sharp I turn and the speed I do it at.
As I have not worked a lot of 4X4, I am not really sure if the resistance I feel when turning the front wheels is to be expected as the CV joints are still turning, even though the 4X4 front traction is not engaged.
Noise doesn't change if I engage the 4X4 in either Low or High and again no change in noise when doing a sharp turn with the Front Axle engaged.
Anyone can steer me in the right direction as what I can do next to further the diagnostic on this grinding humming. I hate throwing parts for nothing at a problem and prefer to have a clear diagnostic before swapping parts.
Any and all insight and help is welcome. If I have forgotten any helpful information please ask.
