FtWorthRam
So in the last month I purchased a 2023 Limited Longhorn Crew Cab 4x4 1500, with the Anti-spin Differential rear axle option. I've never owned a 4x4, but was convinced by a friend and my son that's what I should purchase.....not to mention the vast majority on the dealer lots here in TX are all 4x4. My question is when is it acceptable/advisable to use the 4x4(hi)? I've only put it in 4-wheel Hi once to check it out. It was on some grass, and I heard some popping sounds when I was turning. Is this normal? I read in the owner's manual that 4wd(Hi) mode should only be engaged in loose/slippery conditions. We plan to take it to NM skiing during the holidays, and I want to make sure I utilize the 4wd mode correctly!!
TIA for all your insights, thoughts, and recommendations!!
