which a/t fluid?
wndomn
mwc,ok
1987 d150 swb
newbie to this forum. quick ? 87 swb 318 auto. what does everyone use for a/t fluid? It calls for dex iii but I understand there might be something better. Any help is much appreciated
Jimmy68
Lethbridge Alberta Canada
5.2L Magnum
Sure. Royal Purple.
But Dex III from anybody will be fine. Do your t-case at the same time if you have one.
crazzywolfie
under the truck
some people run atf+4. i think it is supposed to be a bit better overall but cost a bit more.
crazzywolfie
under the truck
i think it is supposed to last longer before breaking down since it is synthetic apposed to the stuff that you would normally run in it.
codered
in da ghetto, FL
1998 QCSB
magnum 5.9/360
ATF+3 or ATF+4 is your best bet. from the words of a wise mechanic who ran DEX 3 in his 727 and it broke down under the heat. He ran ATF+3 and he never went back to DEX 3
