Which wire for reverse camera?
lhcbec
Lake Havasu
3.6 Pentastar
I just put in an aftermarket radio with a dedicated reverse camera wire to connect to the trucks reverse wire. Does anyone know how you determine which wire on the truck to connect it to?
1500ram12
5.9L Cummins
The manual that came with your head unit will tell you what to connect to
Sent from my VS985 4G using Tapatalk
L
lhcbec
Lake Havasu
3.6 Pentastar
It doesn't give the specific wire color of the wire going into the shifter knob.
1500ram12
5.9L Cummins
What head unit do you have
1500ram12
5.9L Cummins
What wiring harness adapter do you have
1500ram12
5.9L Cummins
Without knowing what wiring harness adapter you have all I can show you is what wire off of the head unit is for the back up camera. Since you have a nav unit you should have a nav capable wiring harness adapter which would have a reverse trigger wire. So without more info this is all I can show you. If you are going to tap into the reverse signal wire by the shifter than the website I gave you will tell you what one it is.
L
lhcbec
Lake Havasu
3.6 Pentastar
Fro m the tech authority website I did not find the wiring for the shifter knob. As for the adapter, is this what you are talking about: Axxess XSVI-6523-NAV Wiring Interface?
1500ram12
5.9L Cummins
Yup that's what I needed
1500ram12
5.9L Cummins
Connect the reverse wire from the head unit and the wiring harness and that should be the trigger for the camera
L
lhcbec
Lake Havasu
3.6 Pentastar
It looks like the answer to my question is green/purple!
baum
savage, mn
2015 Laramie
note you MUST connect the reverse cam input from the radio to the wire as long as the cam itself. sometimes i prefer to actually hook the cam power up to a ignition wire instead of this wire. sometimes depending on the cam it take a couple seconds to "focus" so if you go with this wire its not always in focus when you go right into reverse.
L
lhcbec
Lake Havasu
3.6 Pentastar
Good information.
Thanks.
adrianp89
Tampa Bay, FL
One downfall to that is your camera will always be on, shortening the lifespan of the camera.
baum
savage, mn
2015 Laramie
i did reverse cams in cars before they were main stream and factory installed. i have always done it this way and they have lasted longer than then 10 years i had a car. my first reverse cam i did this was was back in 01-02
iralee
