Wire harness
jram1500
I'm going to be installing a new stereo in my 2012 ram. Is there a wire harness so I won't have to cut into the wires in the dash? Can somebody provide me a link?
Would be greatly appreciated
cableguy_hd
Danville, Va.
2020 Ram 2500 CTD
6.7 Cummings
Maybe look at PAC audio? Or ask Crutchfield advisors online
Exdeus
2017 RAM 2500
Cummins
Yes, but it depends on which system you have. Either way, you will have to splice the aftermarket radio wires into the harness wires. I know for my 2010 with the amplified Alpine system I had to use a CHTO-03.
Avoid places like BestBuy, they mark their harnesses up a ton. I would work with Sonic Electronix or Crutchfield to get your part number.
jram1500
jram1500
I have the non alpine. Isn't there a way to plug a harness into the stock harness then the after market deck will splice into that? Then I can go back to stock if I ever need too
Exdeus
2017 RAM 2500
Cummins
Yes, that is exactly what happens.
Basically, you splice the wiring from the stereo into the harness and the harness then simply plugs into your factory wiring. It is pretty simple once you get going with it.
jram1500
jram1500
Awesome. That's exactly what I needed to know
Orca
