Wires melted
Jdaves
Bedford Indiana
I have a 1998 1500 Laramie. I kept blowing the i.o.d fuse. Went through the dash harness couldn't find anything obvious so I put the dash back in hooked everything up went to do more testing and as soon as I hooked the battery back up smoke started rising from the dash and once I got the dash back out the pink wire was melted. Question is what all does the pink wire go to and control
Nealuss
5.2L 318
Not sure if you still need to know, but pink (from the radio harness at least) is battery positive meaning you have a short somewhere.
Goodvibes412
Utah
5.9 Cummins
Any fix for the i.o.d I’ve been having the same problem
Ftank
