Wiring LED cubes directly to your factory fog light wires.
stevens
2015 Dodge Ram sport 4x4 crew
i got some cube led fog light mounts for my fogs/bumper...i want it to be a clean setup...can i wire 2 led cubes to my factory wire for fogs? total of 2 cubes each side. I picked up the same connectors. i also want to do this to my highbeams and retrofit them inside my headlights. people have done this before but just ran a switch into the cab..... i honestly just want a clean setup and use my highbeam toggle and fog light button to trigger them on.
Jimmy07
How many watts is each cube. The factory 9006 fog light bulbs are 55 watts each. You’ll be fine as long as you’re not TOO far over 110 watts total. Same with the high beams. As long as the wattage for the new lights are close to the original bulbs, the factory wiring will be fine.
stevens
stevens
yeah I checked their 20 watts each Cube and hooking up 2 cubes per fog light housing and I'm only hooking up one LED cube for my high beams. So a total of 4 LED cubes for my bumper and 2 LED cubes for my headlights
John Jensen
San Diego County
Ecodiesel
I'm running 4 Baja Design fog quads, 26W / 2A each connected to factory harness via DDM decoders with no problems
