Stevieboy96
If I took out the Y pipe and put x pipe in then put y pipe to tie into muffler will that hurt performance.
This would defeat the purpose of the x pipeIf I took out the Y pipe and put x pipe in then put y pipe to tie into muffler will that hurt performance.
Sent from my SAMSUNG-SM-G891A using Tapatalk
A good y pipe will give you most of the benefits of the x pipe if you want to stick with your current muffler. The xpipe is the most efficient though as it creates more scavenging.Well with what I have read of x pipe was hoping it would help with the exhaust gases being expelled. Didn't know if the Y pipe would negate the effects of the x pipe. Right now just coming up with game plan on doing my exhaust I have a muffler that is one in two out. just was trying to figure best route to go.
That’s what I was thinking too. If he used a dual in dual out muffler then he could use the x pipe correctly but I think those are generally the same size inlet and outlet pipes. Otherwise you might have to use 2 separate mufflers to deal with the different size pipes.
