12 Ram Express
Xpresskit stoped using the 3x lock feature you can no longer buy these kits from them i believe another company does it but xpresskit no longer does
Ok got my kit this afternoon. Will try to get the install done on tomorrow. I don't have internet at my house to do the software but I will go to a friends house tomorrow and get it done.
Had a similar kit installed on my 2013 Blackout Express at my buddies shop yesterday. Question though...does anyone know how to stop the fog lights from coming on when using the remote start? I don't mind my running lights being on but I also had HIDs installed in my heads & fogs and every time I use my remote start my fogs come on with it. The only solution I've found as of now is to just turn my fogs off manually before I shut down my truck when I arrive at my destination. Problem with that is when I get in it to drive away again I have to manually turn them on again even though my headlights are set to AUTO. Yes I know I'm being nitpicky but if there is a solution to this other than me manually doing it I would love to know.
Thanks in advance!!!
If you are using the same type of kit the truck is being fooled into thinking that the key is in the ignition. It's going to do whatever it is told to do by the settings you choose in the truck. If it is a different system then I'm not sure if it is over riding something in the remote start itself.
Sent from Skynet terminal 142a5
The only wire you'd need to run is the purple n brown wire to the bcm connector if you wanted park lights to be on with remote start. I just installed mine
Hood pin not needed.
