here is what the old trans fluid looks like after 175000 km
Probably won't be enough evidence for the ones that rather believe what FCA says...lol.
I completely understand this, I'm one of the what do you call it, shade tree types. I do all my own maintenance and minor repairs. I can address what I understand based on what I know but what about what I don't know, because of my automotive career I realize there is much more to know. Folks will come to conclusions on what they know and understand but what about what they do not know, or even realize there is more to know? How do you know what question to ask when you don't know you should be asking a question?Most people in this thread have better than average knowledge about things automotive, and understand the impacts of lubrication.
And then there's those of us that have the lifetime service agreement and chance voiding it if we change the fluid.Probably won't be enough evidence for the ones that rather believe what FCA says...lol.
I'm still trying to figure out why some chose to change their oil at 3K or 5k mile intervals.
If you change the fluid and use a factory pan and OEM 8/9 speed fluid,they won't be able to tell you changed the fluid.If you plan on keeping the truck long term,that's what i'd do.And then there's those of us that have the lifetime service agreement and chance voiding it if we change the fluid.
I'm not here to argue, but I think you contradict yourself. I change my oil every 3000 miles because of the past/last performance of the known and outgoing formula lubricants. Each an every 'upgrade' may not be an upgrade. When you go from SN to SN+ and now SP, there is absolutely no way any well-known manufacturer knows the performance of the "new and improved" formula going forward. When the new SP formula is released and starting to be consumed in the 'real world', then and only then, can the new data be accrued and analyzed, not before. Before the new data is accumulated and evaluated, you only have whatever testing the manufacturer did. At the point of new release it can only be a speculation based on their laboratory data, and they have their own agenda to fulfill.I completely understand this, I'm one of the what do you call it, shade tree types. I do all my own maintenance and minor repairs. I can address what I understand based on what I know but what about what I don't know, because of my automotive career I realize there is much more to know. Folks will come to conclusions on what they know and understand but what about what they do not know, or even realize there is more to know? How do you know what question to ask when you don't know you should be asking a question?
I had a career in automotive hardware and software design and I worked with some amazingly brilliant people implementing simple algorithms like oil life for example. This isn't something that came overnight, it came from PhDs and years of ongoing studies and research to determine how to calculate oil life. It is a living algorithm and likely is still maturing as does the quality of lubricants.
Unless one had a career in automotive (I don't recommend it) one couldn't possibly know the amount of people, research, design, testing, alpha, beta, and preproduction efforts that go into vehicles. And even with this effort, recalls and TSBs still exist. Every facet of a vehicle from transmission lubricant to something that sounds simple like a power window switch is a universe of complexity within itself.
But that is only half of it, political regulations are overwhelming. Everyone has heard of CARB and their influence in the states. But we designed and build vehicles for the globe, and each political region had its requirements that had to be met. I recall early in my career spending over a year on something as simple as the turn signal flash rate, sounds simple but think about bulb time on, bulb time off, build ramp-up time, etc. The states share a turn signal flash rate, but in Canada, it was different, and differences continued around the globe. Each new year brought a tsunami of new regulations, most incremental.
Many people think they understand lubricants and likely do based on their knowledge. Recognize that there was an army of smart people behind every blend of a lubricant and a long study of the effects of the lubricant versus the wearing of parts. The quality of the lubricant and its performance over time is very well-known by the manufacturers. I guess it is human nature to second guess the manufacturer's recommendations of, for example, lubricant life, or optimal operating temperature of a lubricant. I'm still trying to figure out why some chose to change their oil at 3K or 5k mile intervals.
Nor am I. I just wanted to make known that there is another universe on the other side of automotive service and try to convey its complexities so that you may recognize that suggested service intervals are not grabbed from the air.I'm not here to argue
No problem. New products when introduced are nothing but like a weather forecast, and we know how that turns out. When something new is introduced, we become the data and only time will tell if their forecast is like their prediction or not.Nor am I. I just wanted to make known that there is another universe on the other side of automotive service and try to convey its complexities so that you may recognize that suggested service intervals are not grabbed from the air.
I have considered that, or even paying the dealer to do it - though I think I would be better off doing it myself and acting like it had never been touched. I'm only at 50k miles (with 45k miles being highway miles) so it hasn't been a pressing concern yetIf you change the fluid and use a factory pan and OEM 8/9 speed fluid,they won't be able to tell you changed the fluid.If you plan on keeping the truck long term,that's what i'd do.
