Compass not working ?
Buckeye2019
Florida
2018 Cummins
Anyone have any pics of the compass module in the overhead console
R.L.K.
Bristol , Tn.
Express Man
Sent from my SM-G900R6 using Tapatalk
Express Man
Lol I have 2 for sale. Posting the second one right now. Both have homelink
Buckeye2019
Florida
2018 Cummins
Thanks guys for the pics. I ask cause I bought one a a junk yard and I also bought the premium instrument cluster. When I installed them the instrument cluster had the compass for a minute then it was gone. I have to get the computer flashed then right?
Express Man
Yeah I have same problem. I don't have the compass and it randomly shows the direction in evic
Express Man
Do you have overhead console installed?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
For the compass to work it must be a 2013+ module. The 09-12 look identical except for the part number and button light color.
Express Man
Doesn't the older one still work?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Homelink may still work and not show up in the EVIC, but it's my understanding that while it will plug in it will not communicate on the CANBUS network with the newer clusters/radios.
stimpy433
IOWA
Ok, I've read thru most all the threads i could find about adding Homelink console but didn't find any with my setup. I have the RA3 8.4: radio, the overhead console with overhead lights only, and the small eVIC. Will the homelink overhead console be plug n play, no codes needed??? I have a 2014 Big Horn.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Did your truck come with the RA3? If so, yes it is plug and play.
Ricks Ram
As stated the Homelink will work plug and play in any 13 and up Ram with the RA2 or higher radio. Actually it will work in any 13 and up Ram with the factory overhead console. One thing to remember is make sure you get the Homelink out of a 13 or newer Ram as the part number is different than the earlier versions.
stimpy433
IOWA
Yes, it came with the it. Thanks, I thought it would work but wanted to verify before I bought the console.
stimpy433
IOWA
Thanks for the info guys!!!!
R.L.K.
Bristol , Tn.
Bumping this to move it up only .
Just so others will see it again .
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Does your dad have an overhead console ?
Do you have an overhead console?
No neither of us do.
@RLK,
Since wet were just discussing this in your thread I just noticed that the OP and his dad both had trucks (2014 & 2015) with an RA2 and no overhead console (no compass module) yet the compass heading is supposed to work and does on one of them.
@presten14,
Did you ever get this fixed on your dad's truck?
Up All Night Sleep All Day via my LG G4 on Tapatalk
R.L.K.
Bristol , Tn.
@RLK,
@presten14,
LOL this is one of them I was talking about over on the other thread !
" a working compass RA2 Truck with no o/h console ? Wonder where the compass module is , wonder if these type trucks just use the sxm/GPS puck antenna ?
R.L.K.
Bristol , Tn.
I know this thread is old , but I've recently found out that the compass heading seems to work when non overhead console trucks have a premium cluster ?
Maybe the premium cluster has a compass module within it or it's utilizing the GPS heading from the radios antenna ?
Can anyone she'd some light on this theory?
KAKA
