My Custom RAM GPS mount
Michael Deery
Long Island, New York
3.6 L
hey Spud 2388, I really like your mount because it is closer to the driver and looks highly customized. I agree about hiding the wires. I did snake the wire behind the fascia, but I did use the cigarette lighter socket. If I was comfortable hardwiring inside the dash to the cigarette lighter wiring, I would have done that too. Would love to see some pics of that. Anyway, if I had my gps closer to me, like yours, I would definitely go with the 5" gps, but because mine is further away, I am contemplating the 6" screen. Nice job.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Hi Rado, I just popped the facia panel off. Once you remove the two screws on the top, it just snaps out (held in by clips). I went on youtube and watched a video on how to install a car stereo on a ram just to see how the panel came off. It was very easy. BTW, I like the size of your GPS... is it a 6" screen? I am using my son's 5" garmin now as I had to return a factory refurbed garmin that I bought because it did not work. What size do you recommend? I think on such a big dashboard a 6" might be easier to see. It is a lot further away from me than my gps was on my last car (2015 mini cooper s).
Thanks for the update Mike,, I was looking on You Tube on how to hardwired a GPS using a fuse adapter/splice
https://www.ebay.com/itm/5-x-15A-Ad...078058&hash=item3aaffc504e:g:vMsAAOSw0j9ZQ4az
and plug into this behind the dash! https://www.ebay.com/itm/12-24V-DC-...ash=item4aedcf01bc:g:XdwAAOSwq4VaQ9t-&vxp=mtr
As for my GARMIN Yes it is a 6" Screen to help this old fart see it better lol AT first thought it was too big but got used to it, IMO a 7" would be too big for me ! My G is the GARMIN 69 LMT so I have to use my factory cable for the traffic update ! Now for the Temps to get above freezing lol Thanks for the update
Rich
Spud2388
Raleigh, NC
2017 Sport
It's super easy to tap into the factory socket. The bottom left only runs on accessory power, so it's the one you want to use. Just get a socket off Amazon and use t-taps to wire it up. Zip tie it secure and plug in your GPS. I'll try to grab a few pics when I'm in there again.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Pics would be great Thanks :)
I want to do something like this guy did..
Michael Deery
3.6 L
Thanks Spud 2388, do you know what guage the cigarette lighter wire is or is there a way I can tell so I get the right size t tap? Also, do you know which is the positive or hot leg and which is the ground? Thanks again. The t tap method off the existing socket wire is the way I'd like to go rather than going back to the fuse panel.
Spud2388
Raleigh, NC
2017 Sport
So to get to the stock socket easier, remove the radio bezel (the two top screws under your mount) and give it a good pull. It’ll come right off. Unhook the connectors on the back and then remove the upper screws on the lower portion of the dash piece that contains the socket and pull out change drawer. This allows you to pull it out enough to access the wires of the left socket. The black will be the ground and the other is the power. Not real sure the gauge but any tap should work. I honestly didn’t know they’re different sizes of them lol. I used this one. It has mounting holes to secure it so it doesn’t rattle around. https://www.amazon.com/gp/aw/d/B003...12v+socket&dpPl=1&dpID=41JQS7bTD3L&ref=plSrch
Michael Deery
3.6 L
Great, ty very much. Think I will give a whirl. Seems easier than tapping into the fuse panel. It will keep all of my wiring neatly in the front fascial panel area. I assume I will need no inline fuse as it will be operating on the fuse for the in dash cigarette lighter... correct?
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Spud I like that adapter and good advice on connecting the power,yours kills 2 connections into 1 :) Thanks
kad
Hudson Valley, NY
5.7L HEMI
For anyone who does not want to tap the plug wires and is willing to spend the money, here's an adapter that you remove the connector from the back of the plug, plug the adapter in and then plug the connector back into that. It's pricey, but no wire damage. Also gives you an inline fuse already in place.
https://www.infotainment.com/collections/all/products/12v-power-accessory-kit
-K
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
DITRIO
