Dash cam installation
Toddbigboytruck
Ontario
Dash cams Any installation that you like to share I want to install one but wan it to w
Look good
Toddbigboytruck
Toddbigboytruck
Ontario
It is just do I get a 12 to 5volt and mount it to the fuse box There are no easy to hide the power source
cityredneck
arlington, tx
I've got one, I had a car stereo shop tap the power and run the wire to the top of the windshield (they charged me $50). they tapped into the charging port inside the console next to the cup holders (it is keyed).
Toddbigboytruck
Toddbigboytruck
Ontario
Nice I will contact my local stereo shop do you have a pic ? What one camera are you using
cityredneck
arlington, tx
Just took this oic, hopefully its not to dark, it also just finished raining.
I think its wheelwitness, its says its a 4k, i know it has gps sensor to record the speed but that part can be turned off.
I can get a better pic tmrw of the camera48fc8ac1fd8ce3fd4374a823587ba5a3.jpg
cityredneck
arlington, tx
Got a few daytime pics, the power wire just hangs down from the headliner, the install shop did all the running from the console, under the dash and up the pillar. If i want to hide the pwer wite i can just tuck it in.e4476a1bfc8af122ec7c30c866583813.jpgf1c8af4ffb4c9adb076b9dc088a76dfb.jpg0c11b4a106872090453879c98cc3b9c2.jpg
Addicted2fishing
Durham region
HEMI 5.7
I wanna get one too! I like the thinkware. They can be hard wired in. Comes with front and rear cameras.
Look at the 800 series [emoji106][emoji106]
Tiped on ifone using Tapatalk and auto correct. Can’t you tell?
jawzs2
Air Force
South Jersey
Thats a nice and clean install. Did you think about tapping into the rear view mirror for power? I'm wondering if that is an option.
Thanks, no, I actually ran the wire down the A pillar and hooked it up to the Power Magic Pro hardwire kit. I mounted it under the console and tapped into the circuit for the accessory outlet. Back when I got it there weren't that many options like their is today, and I like the fact that it has a switch where I can enable or disable parking mode, even though it does monitor battery level.
TeamSlacker
MN
John Jensen
San Diego County
Ecodiesel
I hard wired into the mirror wiring. Didn't use the pin method, used a 12v to 5v 3amp converter and tapped right into the wiring.
rotwiler
Washington
Tapped mine to the rear slider switch in overhead console, took around 15-30 mins using twist taps, main time was just taking console out. $10 hardwire kit from Amazon, make sure you know what power connector it uses, some use micro usb, some usb c etc. Also some hardwire kits have 3-5 different plugs so is universal. Only wire you see is from console to cam, about 5 inches. Never a single issue with this setup in a couple years.
regal81455
Illinois
Thats what I did too (with a different converter). Can't remember the name off hand but there is also a company that sells the converter with pins already soldered to the power side.
Yep DonGar. I just don't want to spend double when I have the pins laying around! :)
Tim7139
Alberta, Canada
2020 Classic ST Crew 4x4
5.7 Hemi w/8 speed 3.92 gears
BlackVue also has a power adapter that connects to the OBD port. You can have it on and off with the car, off after a few hours, or off when a battery voltage is reached.
They have one and two camera options, with interior, window, or bumper options for the rear camera.
