Until60
I was wondering where i can get a reamer for 96 1 ton 4wd diesel. I want it to check the taper. I bought tie rod T steering from dodge off road and the tapered bolts do not seem to make surface contact thru the whole taper. They say they have never had a complaint about them. I want to get a reamer that is the correct for my knuckle to just check to see who is right. I don’t know how to check other than maybe buying a new Moog or other tie rod end to check that taper
Any ideas.
Thanks so much
Any ideas.
Thanks so much
