Ram Outdoorsman
- Joined
- Jan 28, 2016
- Posts
- 112
- Reaction score
- 88
- Ram Year
- 2014
- Engine
- 5.7 Hemi
So I installed 2 7inch amber led light bars in my trucks aftermarket bumper where the fog lights would normally go and wired into my fog light wiring. Everything worked until a started the truck and the p/s light started to flicker and the d/s would flicker intermittently. I figured I need to install a resistor in the circuit but not sure if I can use a parallel resistor or if I have to use a different type. The lights are 36w with an operating voltage of between 10-30 volts. If you guys would have any ideas I would greatly appreciate it.
