Evguy1
- Joined
- Feb 9, 2020
- Posts
- 360
- Reaction score
- 397
- Location
- Errington BC
- Ram Year
- 2014 RAM1500
- Engine
- Cummins ISB 170
Just looking for any feedback on power loss when going to 37's with 3.92 gears and a 5.7 Hemi?
You will definitely notice that your stop light performance has taken a hit. It will be a bit of a **** until you get rolling.Just looking for any feedback on power loss when going to 37's with 3.92 gears and a 5.7 Hemi?
Yea those were the numbers I came up with as well. Do you still have to backdate the front diff or has someone started to build gearsets?
I'll start out with the 3.92's and see how it goes. The older I get the less performance I need but I do love the way the 37's fill the wheel openings.
The truck came stock with the 3.92's. It took me a while to find a truck that ticked all the box's for me especially the gears and limited slip diff but this one is close.If you’re spending the time and effort to regear the truck why not just got to the 4.56’s and only spend the money once?
I have 3.92 and 35s. If I’m cruising at 50 mph my truck will be in 8th gear. I wouldn’t mind 4:10s in my truck but 3:92 isn’t far from that so no point for me to swap.Now that I have the 8hp70 swap the 4.56 gears are a bit high . If I slowly accelerate from 0-45 I can go through the first 4 gears supper quick. My 4.56's I believe are starting to whine at about 50-60mph, so I need to get them checked out. 4.56's are not an OEM cut so I know they are a bit noisy, but not like they are right now.
I was wondering if anyone is on 37's with 3.9's and the 8hp70? If I can go back to 3.92's or even 4.10's I can get an OEM cut and they may last a lot longer. I don't want to sacrifice the performance though.
Sorry quoted wrong person......LoLI have 3.92 and 35s. If I’m cruising at 50 mph my truck will be in 8th gear. I wouldn’t mind 4:10s in my truck but 3:92 isn’t far from that so no point for me to swap.
Your actual gear ratio is 4.07 when running 37's with a .456 gearNow that I have the 8hp70 swap the 4.56 gears are a bit high . If I slowly accelerate from 0-45 I can go through the first 4 gears supper quick. My 4.56's I believe are starting to whine at about 50-60mph, so I need to get them checked out. 4.56's are not an OEM cut so I know they are a bit noisy, but not like they are right now.
