Power Mirror Switch
MilesCamp
Shelton, WA & Duncan, OK
5.9 Diesel
I have a 2001 RAM 3500 and my power mirrors adjustment switch will not adjust the mirrors upward - only Left, right & down. I must be asking for the wrong thing because no parts place has an aftermarket switch. I would think this is a simple fix if I can get the part. What should I be asking for or how do I fix my problem?
Cheers,
Miles
Badger 13
North Idaho
2013 Dodge Ram 1500
Can you pull the panel out of the door easily, if so check and see if the Mopar number is on the switch. I just did a quick google and seemed to find quite a few. This one was on ebay, so if it is the style your looking for, the rest of the search should be easy.
Good luck.
Badger 13
North Idaho
2013 Dodge Ram 1500
I'm sure it would help if I added the information....
56021311 1998 2001 DODGE RAM POWER MIRROR SWITCH W/ KNOB Long Wires OEM​
Nealuss
5.2L 318
The switch doesn't exist aftermarket and the chances of finding a new in box mopar replacement are pretty much zilch. Plenty of used switches out there and they fit all 2nd gen rams and I think Dakotas and Durangos as well.
