fengfengfeng
- Joined
- Dec 12, 2018
- Posts
- 78
- Reaction score
- 12
- Location
- china hebei tangshan
- Ram Year
- 2016
- Engine
- Hemi 5.7
16 ram1500 sport with air suspension
I made a mistake. I use alfaobd to write the body height (factory value). But the truck seems to have lost the leveling function. Now loading and unloading cargo can not automatically adjust the body height. And the left side of the body is an inch lower than the right side of the body. It can be raised and lowered manually. The vehicle does not have any fault codes. I cycled the ignition switch many times. Run height sensor check. Drive at low speed for a while. Neither worked.Help me, I have no after sales service here.
alfaobd read system status:
Front Left Calibration Offset(Raw):160
Front Left Calibration Offset:20 mm
Front Right Calibration Offset(Raw):182
Front Right Calibration Offset:254 mm
Rear Left Calibration Offset(Raw):151
Rear Left Calibration Offset:22 mm
Rear Right Calibration Offset(Raw):189
Rear Right Calibration Offset:240 mm
Front Left Level Adjusting Status:Off
Front Right Level Adjusting Status:Off
Rear Left Level Adjusting Status:Off
Rear Right Level Adjusting Status:OffAuto load measurement enabled:Off
I think it has something to do with these. But I can't find any setting about level Adjusting.
thanks thanks thanks
(Started because aero mode became sluggish. I try to view the data with alfaobd. During the test, I turned off the engine by mistake. Then a fault code was thrown. Since I don't know how to do it, I wrote the car suspension height again. Then it became like this. I tried disconnecting the battery. Nothing works.It says done and let me clear the fault code. I'm all done. But still.)
