Driving/Fog Lights
04RAM_3
CA
My 04 doesn't have them. Instead it has the grills in the bumper. I can buy the lights from Amazon. How do I wire them? I'm not concerned about a switch. I'd never turn them off anyway. So would I tap the low beam power supply? Then they would come on with the headlights, and turn off the way they're supposed to when the high beams are on....... Right?
Motorpirate
Kentucky
I wired them to a relay, tripped by the parking lights.
That way they are on with the low and high beams.
I didn't add a switch.
aszumilo
Las Vegas
The harness should already be there for the fog lights. It was on my 04. I have an extra headlight switch for it, if you want it you can have it.
I got my lights off a truck in the junkyard. There are 3 bolts, on each light, that hold the bracket to the truck. If you get them off Amazon, make sure they have the brackets.
Took about 20-30 minutes to install them and put the switch in.
04RAM_3
04RAM_3
CA
Thank you for the offer. Much appreciated
I got them installed today. The lights I bought came with a harness and switch. I wired them in using a spare relay spot in the fuse box for power. They come on with the key and double as DRL's. The switch was rather large and I couldn't find a way inside the cab without drilling a large hole in the firewall, so it's under the hood for the time being
The bezels that came with the kit absolutely do not fit, so I used the ones that were already in the truck with the grill in them. Worked perfectly, and maybe will keep the lights from breaking
