2500 cc long bed
  1. Brevan
    Im stumped. please help!!
    03 ram 2500 5.7 2wd So I was headed to do a job and truck starts running real ******, out of nowhere. Dummy light is flashing, "ok got a misfire.. I'm not quite due for plugs and wires yet" bust out the scanner and its just 0300.. no cylinder is labeled nothing i.e. 0304, 0307 etc. Checked...
  2. R
    Rear engine seal @ 20K .
    Thank you for the add, I'll try and be quick. I bought a 2017 ram 2500 Cummins long box crew cab 4x4 from a dealer with 4800 miles on it, used with a warranty. I just took it in at 20,000 miles with a leaking rear engine seal that they are replacing under warranty. Has anyone had this same...
  3. O
    New Ram Owner
    hey, so I just bought a 97 5.9 Laramie ext cab, runs beautifully while driving, however on first start of the day, if I keep it parked idling it starts to sputter and makes almost a screeching sound, can’t pinpoint it. Any ideas? Also the bed or cab sounds like it’s squeaking on the frame a...
  4. Y
    Transmission shifts hard
    so I am a new owner of diesel trucks. But I’ve been around them all my life. None of the other dodges, Ford, or Chevy diesels have had transmissions shifts as bad as mine. It’s got 128,000 miles on it. But it seems like it struggles to shift into gear. Going from first to second is awful. Like...
  5. M
    Which 2500 Hemi 5.7 or 6.4 ?
    Ive been looking for a 4th gen 2500 crew cab 4x4 long bed. But it seems all I can find in the long bed models is the 5.7! I’ve found 1-2 with the 6.4, but what’s the deal? Can the 5.7 Hemi move all that weight, or is it just a pipe dream? Or should I just keep looking for the “Holy Grail” of a...
rockyj69
