Transmission shifts hard
Yachaa
Athens Georgia
6.7 cummins
so I am a new owner of diesel trucks. But I’ve been around them all my life. None of the other dodges, Ford, or Chevy diesels have had transmissions shifts as bad as mine. It’s got 128,000 miles on it. But it seems like it struggles to shift into gear. Going from first to second is awful. Like the whole truck moves when it does it. Second to third is almost as bad. But third to fourth seems normal. As I just giving it too much gas or is there an issue with the transmission? I’ve owned two other trucks before. I had a dodge 1500 with the hemi and the whole rear end had to be rebuilt but the transmission was fine. The other was a 94 Chevy blazer. It had over 220,000 miles with the original transmission and had no issues whatsoever. So I’m just wondering if I should get it checked out or if this is normal for the newer 4th gen trucks.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Cant see any of that on my phone. :)
I know the 07s had valve body problems and torque converter problems.
When was the fluid and filter changed last ?
huntergreen
Marine Corps Navy Badge
No, not normal. It's possible it's a software issue and you need to do a relearn. A dealer can do this. Also a good idea to change the fluid and filters.
Y
Yachaa
Athens Georgia
6.7 cummins
Alright. I’ll go do the relearn because well like I’ve stated. I’ve only ever driven older trucks and cars. So all this technology and stuff is new to me.
huntergreen
This assumed you have checked for codes.
Y
Yachaa
Athens Georgia
6.7 cummins
like I’ve said. All the new technology in vehicles I have no clue what to do with. So anything with the technology in the vehicle. I have no knowledge of.
huntergreen
Many auto stores, advanced auto and such, can pull codes.
