5.7 camshaft
  1. T
    2022 1500 5.7 Advice Needed..
    Help needed.... I recently purchased a 2022 1500 5.7 v8 with roughly 45k miles on it. I love the truck due to its cab size, smooth ride and performance at higher speeds. I bought in doing what I felt was thorough research although I fully admit I am trying to build my mechanical mind in the...
  2. T
    2021 5.7 Hemi already getting a top end rebuild, good to go or time to move on?
    My 2021 Hemi is getting a new cam, phasers, and lifters at 49k miles. Lucky for me the warranty hadn't run out yet. Everyone is telling me to tuck tail and sprint away from this truck the second it is out of the shop. Should I be genuinely worried about the rest of the engine going to crap, or...
  3. D
    NSR and No Phaser lock Cam 2011 5.7
    Doing a cam/lifter replacement on my 5.7 and want to know if anybody knows any camshafts that are no springs/no phaser limiter required. Also doing MDS delete and already have non mds lifters from comp cams (856Y-16) and new OEM pushrods. Been debating on cams for a few months but have ruled out...
  4. DEON2212
    Looking to make good power
    I'm picking up a 5.7 with 120k miles. I'm thinking of getting an intake, exhaust, hrt stage 1 cam w/lifters, long tubes, and high stall tq. Is there any supporting mods id need (gears, trans, etc)? I want to squeeze more power but still have a reliable truck. Rarely towing a jet ski, mostly...
  5. Manual Gen 4 Ram
    Accidentally misaligned cam and crank... Please help
    2014 Ram 1500 Sport 5.7L After replacing the camshaft and lifters my truck a few months ago I was going into limp mode, but only when the engine was cold. I checked the computer and it showed codes P0016, P000B and the timing changing between -13 and -16° off. The engine ran fine other than the...
  6. 14Deebo
    OEM 5.7 HEMI MDS Camshaft and lifters
    Selling a stock MDS Camshaft and lifter set with trays from my 5.7 2014 Ram 1500. One of the lifters is bad, but I am not sure which one, so you'll have to check them to be sure. Cam and lifters have 53k miles on them and all appear to be in great condition (obviously other than the one bad...
