5th wheel hitch
  1. M
    Need Advice - 2020 Ram 2500 & Towing 5th Wheel Toy Hauler
    Long post but I'm kind of at a loss right now. Truck is a 2500 Laramie 6.4L V8 with standard/short box and 3.73 axle ratio. VIN states: Towing capacity is 14,080 lbs; Payload capacity is 3,014 lbs; GVWR is 10,000 lbs. Right now I'm towing a bumper pull 2012 Keystone Cougar 31SQB. TT is about 36...
  2. Clayton Bearden
    Help! OEM RAM gooseneck with Old B&W Companion
    I just bought a 2019 RAM 2500 Mega Cab with the OEM puck style gooseneck prep package. I want to use my existing B&W Companion 5th wheel hitch Model # RVB 3500 with it. Issue is the Companionl has a square shaft that drops into the hole that requires a locking pin. The OE hitch is a round hole...
Rp3412
