6" lift
  1. J
    6” lift 275/65/20
    2015 Ram 1500 4wd crew cab 5’7” bed big horn ecodiesel. I have a 6” lift on the way right now from rough country, right now I have 275/65/20s on 20x10 -12mm offset wheels. Does anyone have pictures of a 6” with this size tires and wheels I want to see how disproportionately they will look? Also...
  2. TJM62
    Rocky Ridge 2024 Dodge 1500 Rebel Hemi V8
    I want to do a 6” lift through Rocky Ridge on a 2024 Dodge 1500 Rebel. Originally was told it couldn’t be done due to the active safety sensors and cameras. Now the dealer is saying it can be done. Does anyone have this build, can give some input, advice?
  3. b8ascrub
    2021 Bighorn 2” to 6”
    Well I made the leap and bumped up from a 2” level to a full blown zone Offroad 6” lift with a complete fox suspension. The credit goes to @Quick_Shifter for his extreme knowledge and attention to detail on these Rams. If you’re thinking about doing any suspension work and you want to spend...
  4. B
    Installing 6" rough country lift
    I bought a 6" Rc lift for my 2016 1500, first lift I'm installing. Do I need new control arms or can I keep stock. RC said stock would work but I don't trust them. Also getting new rims and tires I've been told I can only run 35x12.5R20. Would I be able to run 37x12.5R17 looking at the Falken...
  5. V
    Lift kits for 2019 Ram 3500 (4"-6")
    Hello guys I recently purchase a 2019 Ram 3500, and ever since I've been planing on lifting it, I looked into BDS and King suspension and no luck I have found some 2" Leveling kits but nothing more, I have also found a Ready lift and Pure performance lift 2"- 6" (links below) but I wanna invest...
  6. Eddy Money
    02 - 05 ram 1500 lift, zone vs BDS
    Looking at zone 5" lift for a 05 ram 1500 4x4 but im wondering if it is woth it to get the 6" BDS instead? Worth the extra $1000? Seems the options are a little more limited for the 02-05.Anybody have them for the 02 - 05 1500s and have comments or opinions? Thanks
  7. MK96
    4" or 6" lift with Rancho quicklift loaded struts
    After going through many lift threads and looking at many pics over here I'm steel confused. I'd like to lift my truck and either go 4" or 6" more likely Zone kit or less likely Fabtech kit. Rancho struts seem not to be adjustable as Bilsteins, though I'd like to keep the front Rancho struts...
