abs light
  1. M
    ABS Pump Motor Repair for 1500
    I have a 2016 1500 and have codes C2200-49 (ABS Module) and C0020-01 (ABS pump motor control). I've been doing a ton of research on this and have found that the pump motor on the Heavy Duty Rams has a very common issue where one or both of the brushes get stuck and cannot make contact. I have...
  2. R
    Abs and brake light on
    Been fighting a demon on my 06 Cummins. Last fall had lights come on and off figured it was WSS. Had code checked for left front WSS circuit. Replaced with new sensor, after that light continuously was on. Had someone ohm out sensor everything checks out. Turns out to be a bad ground wire to...
  3. H
    '09 Ram 1500 ABS
    Hey Guys, Got a '09 Ram 1500 that keeps throwing intermittent right front wheel speed sensor codes. I replaced the sensor and am still getting the code. It will go away when I clear it and then our of no where come on and go off 4-5 time before the srv 4wd light comes on. I think it is probably...
  4. B
    ABS blinking and chiming
    Hey All, was hoping to get some help from experienced voices. I've got a 2002 RAM 1500. The ABS light constantly flashes and dings throughout all trips. If I take the fuse out, the dinging and flashing stop, but I get a consistent ABS/Brake light displayed. The ABS system seems to work fine, and...
  5. A
    2018 Ram 4x4 diesel - "service anti-lock brake system"
    I have a relatively new 2018 Ram 3500 4x4 with a 6.7l diesel. This morning while driving the truck went over a bridge expander bump and now I am getting two errors: 1) Service anti-lock braking system with the ABS light on; 2) Service electronic brake system with the traction control light lit...
  6. DaveRam2500
    2014 ram 2500 6.4L ABS issues
    I had my ABS light come on about a month ago. I scanned it, said right front ABS. (I’d have to go back for the code, forgot off top of my head). I changed the sensor. Didn’t work, changed the hub assembly to MOOG. light didn’t go away. Checked voltage. Old sensor on driver side was reading high...
  7. O
    ABS light on dash fixed
    I had the all too familiar ABS and Brake lights on the dash. Mine went further by causing the truck to stall at lights. Speed sensor (rearend, fuses) not fixed. My mechanic said all the codes pointed at the ABS module. When he removed the original unit, it fell apart in his hands. Two things. 1)...
