abs module failure
  1. M
    Abs module recall
    I know this was discussed in the past but looking for any information about if or when they may cover my year. 2016.
  2. M
    ABS/PDC Failure Question
    Hello all, I have a 2016 PowerWagon with 228K miles 9I've done a lot of hauling accross the midwest with it) that has been throwing the the following codes: c121c-00 and b16b7-15. My family mechanic said to take it to the dealership – which I did with apprehension. Dealer suggests replacing...
  3. M
    ABS Pump Motor Repair for 1500
    I have a 2016 1500 and have codes C2200-49 (ABS Module) and C0020-01 (ABS pump motor control). I've been doing a ton of research on this and have found that the pump motor on the Heavy Duty Rams has a very common issue where one or both of the brushes get stuck and cannot make contact. I have...
  4. D
    2018 RAM 2500 ABS problems
    2018 RAM 2500 Diesel ABS Brake Problems. I have read many discussions and how tos on fixing this problem with ABS brake light coming on intermittently. The problem seems to be in the ABS unit which has had many problems and I ink many of you have had them replaced several times at the dealer...
