ac compressor clutch
  1. CaddyMan1984
    AC Clutch quit engaging? Can it be related to a Blend Door Failure? 2006 Cummings
    My blend door(s) are broken. Have been for some time but my AC would still push enough air through the vents to be liveable until a few days ago. Now the idiot light comes on but the clutch does not engage. Static check of the system pressure shows good. Does anyone know if the Blend/Recirc...
  2. ajamesd78
    A/C compressor won’t engage
    2007 Dodge Ram 6.7 Mega Cab with and A/C compressor that won’t engage. I checked the wires and they are connected at the compressor. Dash lights up when A/C button is pushed but the compressor doesn’t react. Before following other advice online of replacing a TIPM, I just wanted to ask around if...
  3. A
    AC Compressor won’t turn on
    Hey all, Thought I would turn to the experts on some major trouble I’ve run into while recharging my A/C! I am finally recharging my AC after doing cam/lifters over the winter. Everything was going well until I was attempting to add the Freon when I could not get the compressor to turn on. I...
  4. H
    AIR CONDITIONING ISSUE
    2009 Ram 1500 Laramie with AC issues. -All actuators I can get to immediately behind dash work properly. -Compressor and belts were replaced. - Thermostat was replaced. Here is what is happening after Compressor and Thermostat were replaced. Any idea what could be causing it? AC set on Lo...
  5. 2
    AC issues
    2007 Dodge Ram, 5.7 Hemi - not able to charge AC unit. Checked operation of blower, cleaned condensor, clutch engages on condensor. Using only standard single line with gauge to charge. Gauge goes up when compressor turned off (as it should I believe) but goes to zero when compressor on. ANy...
  6. S
    AC clutch replacement without losing pressure
    Hey guys, just thought I would share my clutch replacement experience with you. Hopefully it will help out someone else with the same problem. First thing was the diagnosis. The AC was not working, nor was the clutch engaging. Next step check the refrigerate and make sure there is pressure...
  7. GordDavey
    A/C Compressor Clutch - Diagnosing
    Hi All, I'm having a problem with the A/C in my 2015 Ram 1500. As it was rebuilt after an accident, I highly doubt any warranty would be valid, that being said I have 1 issue left to resolve with the truck, my A/C not working. My professional mechanic is also a licensed A/C guy, but has never...
