ac issues
  1. D
    Air conditioner will randomly stop working
    2016 ram 1500 5.7 V8 About two months ago, I noticed while driving my air conditioning was blowing warmer than normal, it wasn’t hot, but it wasn’t cold. I would turn the AC off, then turn it back on and it would start working. After a while, it started acting up more and more and all I had to...
  2. C
    2017 Dodge Ram A/C issue air drier plug
    My AC is gone on my 2017 Ram 1500 Hemi, found tsb on air drier filter and leaking at the plug. Has anyone replaced this and how difficult is it to do? Can’t find anywhere showing how to do it so came here to ask around.
  3. Ryan J
    Ac clutch engages but pressures stay the same
    My ac wasnt working so i figured it needed recharged as i have had to rechage it the last couple summers. So today i did that. Pulled a vacuum, put some refrigerant in it and the pressure never dropped on the low side. I checked the clutch and it was engaged, warm air blowing. I had 100psi on...
