air intake
  1. HemiGman
    Air Intake Replacement Filter
    I’d like to know if the E-3840 K&N OVAL AIR FILTER will fit the VARARAM VR-GRABBER 4G AIR GRABBER 4TH GEN 5.7L HEMI TRUCKS; 2009-2020 as a replacement filter? And if so, will it be better or should I stick to the original?
  2. DoubleJ
    4th Gen Parts - Stock Intake Manifold and Catch Can
    Stock 5.7l Intake Manifold was taken off a 2014 1500 with 72000 miles on it. Worked flawlessly before removed and was removed and stored with care at the beginning of Nov 2020. No visible damage to report. Includes fuel rail and injectors, as pictured. Can include stock engine cover. $150 plus...
  3. Dhubble
    Water pump replaced twice since emissions recall
    So I've had my truck for about 3-4 months since the Emissions flash was done. I noticed coolant leaking a month after I drove it. Took it in and the replaced my t stat and water pump. Brought it home and it was leaking again a few days later. They replaced it again. Now I'm a few months into...
  4. J
    sputters on load
    I have an 1989 W100 with a 318.... it idles fine runs fine when just taking it easy but when I accelerate fast or have to take off on a hill or anything that puts any load on the engine it sputters like it is miss firing. Suggestions? Asked a mechanic friend and he asked if it had a Mass Air...
  5. B
    Air box to throttle body boot on magnum 4.7
    I am a new owner of this truck and was having some issues with the truck stalling immediatly after start up it would run for a few seconds and fall on its face. I got it taken care of and realized some of the neglect the previous owner has shown this truck. First of all as I removed the air...
  6. Christian1500
    Swoosh or Air noise question (CAI)
    So I been hearing this swoosh or air noise coming from the cold air intake area (Spectre cai :argue:), and its mostly happening when I'm speeding up in the highway and then letting off the gas pedal; it sounds like the air is coming back from the aluminum tube and to the air filter and out...
  7. S
    Engine up grades
    Okay I’m thinking of doing some upgrades to my engine starting with a throttle body spacer and ram air intake. I was also thinking of switching out the coil packs and sparks plugs for higher rated coil packs and spark plugs with a wider gap. Would those be worth it? Plus injectors, what are the...
mikeynosikey444
