air suspension delete
  1. R
    Advice on air supension delete
    Hello! 2013 Ram 1500 Laramie. 190K miles. 4th compressor needed, previous were in warranty. Dealer wants $5200 to replace. My thoughts are it's time to pull and replace with coil overs. I'm primarily a highway driver but I do have a 30ft boat that weighs about 5k lbs that I pull occasionally. I...
  2. B
    ALPHAOBD Air Suspension Delete on 2016 Ram Rebel Help Please?
    I have a 2016 Ram Rebel that I have successfully removed the Air Suspension from. I have used ALPHAOBD to remove what I thought was everything. I have removed the 2 fuses 1, 20amp and the 1, 40amp. I then used Alpha to disable the ASCM Air Suspension module under P/T Chassis Net: ASCM air...
