Ball joint not sitting flush
Hi there,
2016 ram 1500
I got a new ball joint for my mevotech front lower control arm. I have pressed it in and it sits way too high. About a quarter inch is between the control arm and where the clip sits. I have attached photos. I double checked and they are the...
I'm new so sorry if this was posted once but I couldnt find one that had same issues.
I have a 2012 ram 1500 5.7 hemi with 4wd. I took it to get new tires and a alignment and was told they couldn't due to the ball joints being bad.
So I changed them myself and now when I reach speed over 35mph...
I have 2014 Laramie 4x4 and the other day my upper ball joint popped out. Today I bought a new uca with a pressed ball joint and after installing the ball joint seemed to raise slightly from the control arm. Should I be concerned or is this normal or should I be concerned? I bought the uca from...
I have a 2001 2500 4x4 with a Dana 60 front end, I'm trying to replace the ball joints, I have pulled the 4 bolts out of the bearing housing and I tryed the trick with the power steering (pushing on the bolt head with a socket and extension) it will not work for me it is very rusty, does anyone...
