brake controller
  1. K
    Trailer Brake Controller issue
    I have a 2017 Ram 1500 Limited with the OEM brake controller installed. Recently when a trailer is connected I get brake lights, turn signals, but no trailer brakes. The trailer brakes work fine using another truck. When the trailer is attached the display flashes connected then not...
  2. kraizter
    Brake Controller - 4 Way and OEM Controller Socket
    So I have an 06 1500, it has a 4 way in back and a empty mounting spot in bumper for 7 way. I have found the blue OEM brake controller socket for quick plug brake controllers. However, I am confused since there is no 7 way in back, is the trailer brake power wire already run to the back of the...
  3. S
    2018 Brake Controller
    Hi all, I brought my truck the the dealership this week to have a trailer brake installed to pull my camper. They told me I already have the tow package and just needed it programed. I got my truck back and noticed I can access the tow menu through the steering wheel now, but I have no way to...
  4. D
    Trailer Brake Controller Problem
    I'm having trouble with my trailer brake controller. The controller periodically warns to Check Trailer Wiring, after two to three times of this warning it warns Trailer Brake Disconnected. These warnings come and go seemingly randomly. I've had the trailers brakes examined they're fine...
  5. Josh610
    2016 soft Breaks
    I have a 2016 ecodiesel that has a soft break pedal. last 30% dose all the breaking. I have bleed the system a few times and i don't think it has changed a bit. with the truck off u can have and hold a hard stiff pedal till u start it? any ideas what this might be?
  6. R
    Installed new oem trailer brake controller, no luck
    I was all excited when I installed my own oem trailer brake controller and had the dealer enable it in the computer. Everything appears to present and working in the dash computer / menus. Problem is, the trailer brakes didn't work. Testing the plug at bumper, the brake pin gives constant...
  7. J
    Integrated Break Controller
    I am having issues towing a 12k 5th wheel. The first 900 miles no issue. The second day the controller kept flashing service brake system and going in and out connection flashing warning info on the dash. I checked the wiring on the plug and trailer and everything thing looks and tests out...
jimn
