brake pads
  1. dburkard
    Feedback about Upgraded Towing Brakes (Rotors, Pads & Calipers) for a '15 2500 4x4 6.4l
    Looking for feedback on upgrading rotors and pads (calipers too). Looking for those who have seen improvements while towing loads in the mountains? I have had good experiences in the past with using drilled & slotted rotors, so I am looking for any experiences you may have with ones like that...
  2. R
    Brakes
    I was wondering about doing brakes. When sliding the new pads in is it ok if they are tight against the rotor or do they have to have a space and be kind of springy. I placed mine in and they are tight against the rotor so I stopped in case this was incorrect. Any help will be greatly...
  3. 1ATony
    Rear premium posi ceramic brake pads for 2011-2018 Ram 2500 trucks
    Shop here for great prices and quality brake pads from TRQ: 2011-2018 Ram 2500 Truck Rear Premium Posi Ceramic Brake Pads Includes: Brake pad contact point grease Brake pad hardware
  4. 1ATony
    2011-2016 Ram 2500 Truck Front & Rear Premium Posi Semi-Metallic Brake Kit
    Great prices and free shipping! 2011-2016 Ram 2500 Truck Front & Rear Premium Posi Semi-Metallic Brake Kit Part # 1ABFS02524
  5. TheJLowe
    Squeaking Brakes
    Hey All, I had some squeaking brakes on my 2016 Ram 1500 so I figured I go ahead and upgrade my brake pads and rotors with R1 Concept Rotors and EBC Green Stuff 7000 brake pads since it *** almost time anyways. I installed them about a couple months ago and have put well over 6000 miles on them...
  6. R
    Need Help with Brakes - Pedal going to floor
    2007 Ram 1500, quad cab, 270,000 miles: I just changed rotors, pads, and calipers all around. I have bleed the brakes 6 or 7 times starting at the passenger rear and working toward the master cylinder. I have bleed the brakes with the key on, in the ignition, out of the ignition, and with the...
  7. TheJLowe
    Brake Pad Suggestions for Daily Driver
    I have a 2016 Ram 1500 and I'm in line to get some new brake pads and I was looking at AutoZone's Duralast Max Brake Pads (Ceramic). If I don't have to go Mopar, I'd like not to but want some pads that are going to last, not squeak and do a good job. I rarely do any towing/offroading and no...
rockyj69
