Best Oil for a Slant Six?
RGC440
bixby ok
Yardbird, I have not researched this, but I think the early /6 was during the time that it voided the warranty if you used multi grade oil.
metalchewy
Las Vegas
2010 TRX4
4.7L
ever since Valvoline VR1 came out I've been using their 10w40 in my old 273. It has a higher zinc content so I no longer deal with the additives on my oil changes for the flat tappet mechanical lifters.
Most of the standard dinosaur oil no longer has the zinc these cams and lifters need.
Dusty
Rochester, New York
My '82 Ram D150 with Slant Six engine needs an oil change. Though Dodge calls this version of the D150 the "Miser" I never skimp on the best multi-viscosity synth oil available.
But what viscosity makes most sense ? We have mild winters, never below zero, with summers rarely above 100.
Since I happen to have a Dodge truck service manual for that year:
LUBRICATION
For Service SE only
Ambient temp over 32F - SAE 30, 40, 10W-30, 10W-40, 10W -50, 20W-40, or 20W-50
+32F to +10F - SAE 10W-30, 10W-40, 10W-50, or 20W-20
+10F to -10F - SAE 10W, 10W-30, 10W-40, 10W-50, 5W-20, 5W-30, 5W-40
Below -10F - SAE 5W-20, 5W-30, or 5W-40
(They still make a 20W-20?)
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 132333 miles.
metalchewy
Las Vegas
2010 TRX4
4.7L
Regards,
Dusty
Isn't that just SAE 20 weight oil?
I haven't seen that for years.
Dusty
Rochester, New York
Yeah, neither have I.
Since there's a winter blend "W" in the in the type, I suspect it is not straight 20 weight oil.
Regards,
Dusty
Marshall
Sk, Canada
2014 sport
My take, any new oil, 10/30 usally is better then any old oil. In that motor, it will not really care if it's in good shape. if its blowing some smoke, then step up to next weight. You have to be careful of the tree huggers in BC,:D
MrBonez
Central Alabama
2008 Laramie Quad Cab
Been running 15w40 Delo with a 10% Lucas mix in my old S10's 4.3 for years and it's still running strong (300,000+ miles), gives a puff of smoke when it's started cold and maybe for 30 seconds afterwards if that long.
Really doesn't use oil between oil changes either.
I'd suggest about the same for your slant because those engines were spec'ed (Engineered) for oil of that weight range, usually 10w30 works fine in them but it has some miles by now so it's not a bad move to step up to the next oil weight range and keep driving.
Marshall
Sk, Canada
2014 sport
Up in this country , winter temps are usually freezing to -30 so 15/40 would be a bit heavy unless kept inside or block heater used.
Summer time it would be just fine.
Yrs ago I had a S10, great little truck running around the farm, forget what year, 4 sp, smaller motor, 2.8? maybe, fellow down the road wanted it , so I bought a 89 Dakota .
MrBonez
Central Alabama
If it was a V6 then it was either a 2.8 or 4.3, 4 speed trucks were all 2.8's that I'm aware of.
Mine is a 4.3 with a 5 speed and it's a 4x4 truck too.
SKYDOG 69
225 slant six
Down here in central Fl with a 83 D150 Miser/slant 6. Man i'm just gonna stick with the old Lucas 10w30 Classic. Several option's i know, and all are purty good. Maybe i am going overboard with the old slant six.But i put in 5 qt's of the Lucas and 1 qt of the stabilizer. What the heck. Spoil the old gal.
Hagar1
Ontario Canada
2012 Ram 1500
I thought the Slant Six would run on rendered yak fat...
Probably would! The old "leaning tower of power" was one of the most reliable engines "out there" right up until they went with hydraulic lifters.
rockyj69
