clutch replacement
  1. S
    AC clutch replacement without losing pressure
    Hey guys, just thought I would share my clutch replacement experience with you. Hopefully it will help out someone else with the same problem. First thing was the diagnosis. The AC was not working, nor was the clutch engaging. Next step check the refrigerate and make sure there is pressure...
