coil ignition coil
  1. C
    3.6l cylinder 2 misfire
    Hey everyone, running into a little issue. I have a 2018 Ram 1500 3.6 51,000 miles. Been showing a cylinder 2 misfire, went in and switched plugs, still persistent. I am going to be changing the coil today and see if the issue is still around. My question is really residing, in the fact that, I...
  2. H
    2014 1500 5.7 Hemi Ignition coil and spark plugs help ASAP
    Hi, I am new to this forum and owning a Ram. I found Rockauto to be more reasonably priced in comparison to O'Reilly's, Advance and etc. I would like to get recommend the correct OEM Coils and Spark plugs to order off Rockauto. I get confused reading other forums and I'd appreciate getting...
  3. L
    Ignition coil
    1997 ram 1500 5.2L Truck not starting When I put a spark plug on the wire coming off the ignition coil and ground it no spark.... There is 12v on both the constant power and also on the trigger/signal wire is that normal?
